Basic Configuration Wizard
The Universal Compute Platform software provides a Basic Configuration Wizard that can help administrators configure the minimum settings necessary to deploy a fully functioning appliance on a network.
Administrators can use the wizard to quickly configure the appliances for deployment, and then after the installation is complete, continue to revise the configuration accordingly.
The wizard is automatically launched when an administrator logs on to the appliance for the first time, including after the system has been reset to the factory default settings.
The wizard prompts you with a series of yes or no, multiple choice, or manual entry questions that you must answer with the desired configuration settings. The following conventions apply:
