Export VIQ Account
Use this procedure to create and download an export file for a VIQ account.
  1. In ExtremeCloud IQ Pilot, go to Global Settings and select VIQ Management.
  2. Create a backup of the current VHM:
    1. Under VIQ Management, select BACK UP NOW.
    2. Select YES.
      VIQ suspends itself until the backup completes.
  3. Export the VHM to a local drive:
    1. Go to Global Settings and select VIQ Management.
    2. Select Export VIQ.
    3. In the VIQ Export popup window, select Export Now.
    4. Click YES. VIQ suspends itself until the Export completes.
    5. Once the export completes successfully, select OK.
      If the export fails, click the Detailed Report link to get a detailed report on the issue.
What to do Next
After the export file downloads, you can import the file into a different Regional Data Center (RDC).
