An engine is an instance of a containerized application.
This process follows the user interface to configure the orchestration engine settings.
From the management IP address, log into the user interface using the admin credentials
that you configured under Use the Basic Configuration Wizard.
Go to Cluster
Settings > Cluster
Configuration and configure the cluster following the order shown on screen:
Deployment
Type
Cluster Node Information
Pod Network
Configuration
Finish
Select Distributed Cloud
Deployment in the Deployment Type
drop-down list.
Provide the settings for
Pod Network
Configuration:
