Before configuring the cluster, use
your Extreme Support account to download the latest revision of Universal Compute
Platform firmware from the support portal: https://extremeportal.force.com/. At this time, UCP 5.04.01 is the minimum required
revision.
Log in to the controller Admin
user interface: https://node ip:5825
Go to Administration > System > Software
Upgrade > Upload.
Upload the desired revision of
Universal Compute Platform.
A best practice is to
upgrade each of the nodes on a new cluster to the latest revision before
proceeding with the cluster set up and configuration.
Select the upgrade
From the Image Management
Tab, select the Upgrade image, and select .
In the popup window, complete
the following fields:
Image—Select the platform image file.
Backup System Image
to—Select Local.
Upgrade—Select Now.
Upgrade the selected
Select Upgrade.
When all nodes in the cluster are upgraded
to the latest revision, proceed to IP Address Configuration.
