VRRP Configuration
In support of load balancing and high-availability functions, the Universal Compute Platform relies on Virtual Router Redundancy Protocol (VRRP) to provide IP abstraction to key functionality. VRRP is critical in the configuration model.
The following operation settings must be defined as part of the VRRP configuration of member nodes:
Inter-Cluster VRRP Configuration
An Inter-Cluster Connection refers to the back-end interaction and synchronization between all the members of a cluster. Minimum required connection requires 10 Gbps between nodes.
Table 1. Inter-Cluster Connection VRRP Configuration
Nodes 1 -6 (Port #)
ICC
  • Node 1 ICC IP /CIDR
  • Node 2 ICC IP/CIDR
  • Node 3 ICC IP/CIDR
  • Node 4 ICC IP/CIDR
  • Node 5 ICC IP/CIDR
  • Node 6 ICC IP/CIDR
VLAN VLAN Tagged/Untagged
Port type Physical
VRRP
VRRP IP addresses ICC VRRP IP
Priority Set a unique priority for each node. For example:
  • Highest (200)
  • Next (150)
  • Medium (100)
  • Next (75)
  • Next (50)
  • Low (25)
Router ID ID (2)
Services VRRP Configuration
The VRRP configuration relates to the number of services you are exposing. Configure a VRRP IP address (VIP) for each service.
Table 2. Services VRRP Configuration
Nodes 1-6 (Port #)
Data Port Node Port IP /CIDR. Unique Port IP for each node.
Port type Physical
VRRP
VRRP IP address (VIP) 6 VIP addresses. Unique VIP for each node
Priority Unique priority value for each VIP
Router ID ID (1)
