ExtremeCloud Edge
This guide outlines the steps required to prepare a cluster environment that will support deployment of ExtremeCloud Edge applications to the customers' premises.
Minimum Requirements for Installation
Application requirements for the cluster configuration:
Service Set 1: Cluster Administration, Account Access (https), CAPWAP Master, Diagnostics
Table 1. Example port assignments for Service Set 1
Protocol Port Service Description
TCP 443 NGINX ExtremeCloud IQ Admin, software management
TCP 2083 IDM IDM Auth
TCP 80 CAPWAP CAPWAP Master
TCP 12222 CAPWAP CAPWAP Master
TCP 1443 XAPI ExtremeCloud IQ API
Service Set 2: AP Registration/CAPWAP Load Balancing
Table 2. Example port assignments for Service Set 2
Service Set 3: AP Registration/CAPWP Load Balancing
Table 3. Example port assignments for Service Set 3
Service Set 4: AP Registration/CAPWP Load Balancing
Table 4. Example port assignments for Service Set 4
TCP 443 NGINX ExtremeCloud GDC access
