Add Node
Before adding a new node, you must configure the new controller and ensure that it is running the current firmware version. Refer to Prepare to Replace a Node.
A node is one appliance. Universal Compute Platform clusters typically support up to three or more nodes, with the ability to scale up when the cluster reaches capacity.
To add a node to a cluster, take the following steps:
  1. Go to Cluster Settings > Add Node.
    Add Node dialog
  2. Provide the appliance IP address for the node and select Add Node.
    The Node Addition confirmation dialog displays.
    Add Node Confirmation Dialog
  3. Select OK to begin the Add Node process.
