establishment-criteria
Configures L2TPV3 tunnel establishment criteria
A L2TPV3 tunnel is established from the current device to the NOC Controller when the current device becomes the VRRP master, cluster master, or RF Domain Manager. Similarly, the L2TPV3 tunnel is closed when the current device switches to standby or backup mode.
  • Access Points — AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432, AP8533
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
establishment-criteria [always|cluster-master|rf-domain-manager|vrrp-master <1-255>]
Parameters
always
Always establishes a L2TPv3 tunnel from the current device to the NOC controller. This is the default setting.
The ‘always‘ option indicates the device need not be a cluster-master, rf-domain-manager, or vrrp-master to establish a tunnel.
cluster-master
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the cluster master
Note: The l2TPV3 tunnel is closed when the current device switches back the standby or backup mode.
rf-domain-manager
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the RF Domain manager
vrrp-master <1-255>
Establishes a L2TPv3 tunnel from the current device to the NOC controller, only when the current device becomes the VRRP master
  • <1-255> – Specify the VRRP group number from 1 - 255.
Note: The L2TPV3 tunnel is closed when the current device switches back the standby or backup mode.
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#establishment-criteria
cluster-master
nx9500-6C8809(config-profile default-rfs4000-l2tpv3-tunnel-Tunnel1)#show context
 l2tpv3 tunnel Tunnel1
  establishment-criteria cluster-master
Related Commands
no
Resets to default (always)
