Smart-sensor automates provisioning of APs as sensors without compromising network security. When enabled, 1/3 of the deployed APs' sensor radios are turned on automatically. In a Smart-RF monitored deployment, neighbor details and configuration updates are collected in the Smart-RF neighbor table. The Smart-sensor feature puts this neighbor table information in to an algorithm to create a cluster of cells. Each cell in the cluster represents an AP and adjacent cells are the AP's neighbor. The algorithm then identifies APs with best coverage area and provisions them as sensors.
The smart-sensor feature is only supported on the tri-radio, AP8533 model AP.smart-sensor
None
nx9500-6C8809(config)#smart-rf-policy smt-sensor
nx9500-6C8809(config-smart-rf-policy-smt-sensor)#smart-sensor
nx9500-6C8809(config-smart-rf-policy-smt-sensor)#smart-sensor-algorithm cell-size [dense|sparse])
nx9500-6C8809(config-smart-rf-policy-smt-sensor)show context include-factory | include smart-sensor smart-rt-rf-policy smt-sensor smart-sensor smart-sensor-algorithm cell-size sparse nx9500-6C8809(config-smart-rf-policy-smt-sensor)#
nx9500-6C8809(config-rf-domain-smt-sensor)#use smart-rf-policy smt-sensor
nx9500-6C8809#trigger-smart-sensor on smt-sensor
Alternately, if the RF-Domain manager is an AP8533, you can trigger Smart-sensor calibration locally on the RF-Domain manager.
ap8533-137E1D#trigger-smart-sensor
| no (smart-rf-policy-config-mode-command) | Disables the smart-sensor feature |
Print
this page
Email this topic
Feedback
