no (ipv4-acl)
Removes a deny, permit, or disable rule
  • Access Points — AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432, AP8533
  • Service Platforms — NX5500, NX7500, NX9500, NX9600, VX9000
Syntax
no [deny|disable|permit]
no [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp]
<RULE-PARAMETERS>
no disable [deny|permit] [<NETWORK-SERVICE-ALIAS-NAME>|icmp|ip|proto|tcp|udp]
<RULE-PARAMETERS>
Parameters
no [deny|permit] <NETWORK-SERVICE-ALIAS-NAME>icmp|ip|proto|tcp|udp] <RULE-PARAMETERS>
no [deny|permit]
Removes a deny or permit rule from the selected IP access list
Removes a deny or permit rule applicable to the specified network-service alias
  • <NETWORK-SERVICE-ALIAS-NAME> – Specify the network-service alias name (should be associated with the deny/permit rule).
icmp
Removes a deny or permit rule applicable to ICMP packets only
ip
Removes a deny or permit rule applicable to IP packets only
proto
Removes a deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP)
[tcp|udp]
Removes a deny or permit rule applicable to TCP/UDP packets
<RULE-PARAMETERS>
Enter the exact parameters used when configuring the rule.
rule-precedence <1-5000> rule-description <LINE>
Specify the precedence assigned to this deny/permit rule.
  • rule-description – Optional. Specify the rule description.
Note: The system removes the rule from the selected ACL.
<RULE-PARAMETERS>
no disabled [deny|permit]
Removes a disabled deny or permit rule from the selected IP access list
Removes a disabled deny or permit rule applicable to the specified network-service alias
icmp
Removes a disabled deny or permit rule applicable to ICMP packets only
ip
Removes a disabled deny or permit rule applicable to IP packets only
proto
Removes a disabled deny or permit rule applicable to protocols (other than IP, ICMP, TCP, and UDP)
[tcp|udp]
Removes a disabled deny or permit rule applicable to TCP/UDP packets
<RULE-PARAMETERS>
Specify the precedence assigned to this disabled deny/permit rule.
Note: The system removes the disabled rule from the selected ACL.
Usage Guidelines
Provide the rule-precedence value when using the no command.
The following example shows the ACL ‘test‘ settings before the ‘no‘ commands are executed:
<exsw1>(config-ip-acl-test)#show context
ip access-list test
 deny proto vrrp any any log rule-precedence 600
            deny proto ospf any any log rule-precedence 650
<exsw1>(config-ip-acl-test)#no deny proto vrrp any any rule-precedence 600
<exsw1>(config-ip-acl-test)#no deny proto ospf any any rule-precedence 650
The following example shows the ACL ‘test‘ settings after the ‘no‘ commands are executed:
ip access-list test
