use (meshpoint-config)
Uses a QoS (Quality of Service)
policy defined specifically for meshpoints. To use this QoS policy, it must be
defined.
Configured on WiNG 7.1.X controller
and pushed to the following WiNG 5.9.X APs:
- Access Points — AP7502, AP7522,
AP7532, AP7562, AP7602, AP7612, AP7622, AP7632, AP7662, AP8163, AP8543, AP8533
Syntax
use [aaa-policy <AAA-POLICY-NAME>|meshpoint-qos-policy <MESHPOINT-QOS-POLICY-NAME>]
Parameters
<MESHPOINT-QOS-POLICY-NAME> |
Configures this meshpoint to use a predefined
meshpoint QoS policy
- <MESHPOINT-QOS-POLICY-NAME> – Specify the meshpoint QoS policy
name (should be existing and configured).
| aaa-policy <AAA-POLICY-NAME> |
aaa-policy
- <AAA-POLICY-NAME> – Specify the aaa-policy name (should be
nx9500-6C8809(config-meshpoint-test)#use meshpoint-qos-policy test
nx9500-6C8809(config-meshpoint-test)#show context
meshpoint test
description "This is an example of a meshpoint description"
meshid TestingMeshPoint
shutdown
beacon-format mesh-point
control-vlan 1
allowed-vlans 1,10-16,18-23
neighbor inactivity-timeout 300
data-rates 2.4GHz bgn
data-rates 5GHz an
security-mode psk
root
