efa supportsave
Collects the support-save of the Inventory, Tenant, and Fabric service logs, and their associated database dumps.
Syntax
efa supportsave
Usage Guidelines
The supportsave file is saved to /var/log/efa/efa_<log-id>.logs.zip.
This example collects the supportsave logs.
sudo efa supportsave
Version: 2.1.0
Build: GA
Time Stamp: 20-01-31:15:11:36
Support Save File: /var/log/efa/efa_1586909025.logs.zip
