You can upgrade or reinstall
EFA.
Remove the existing
/efa installation folder.
Follow the installation steps in
Install EFA on an External Linux Server.
The Installer includes the following packages and does not require internet
connectivity.
- Postgres database
- Rabbitmq
- Goinventory service
- GoFabric service
- GoTenant service
- GoSwitch service
- Konga
- Kong-API-gateway
- Metricbeats ELK Dashboard Stats/healthcheck monitor (available in ELK
dashboard)
- Filebeat-deployment
- Kibana
- Logstash
- Elasticsearch
- vCenter
- Openstack
- HyperV services
If the previous deployment stack is running, the deployment script
presents the following options:
- Remove the current stack. Select this option to remove the
entire stack.
- Upgrade or Redeploy. If you are running the deployment script
from the new tar ball, select this option to upgrade without wiping
out the current database. You have this same option if the script is
run from the same folder, in which case the stack is
redeployed.
- Quit. Select this option if you do not want to change the
current stack.
