MCT peer and VE validations are platform specific.
								 Use Case  |
								 Valid  |
								 Invalid  |
								 MCT Cluster Name  |
								 MCT Cluster Name is different from fabric name in fabric properties. MCT Cluster Name learned from device is used while configuring the device, so that the cluster name is reconciled.  |
								 Cluster Control VLAN  |
								 Cluster Control VLAN matches with “Control VLAN” of fabric settings.  |
								 If the VLAN does not match, an error is displayed.  |
								 Cluster Control VE  |
								 Cluster Control VE matches with “Control VE” of fabric settings  |
								 If the VE does not match, an error is displayed.  |
								 MCT Peer IP  |
								 Peer IP address is within IP range of “MCT Link IP range” of fabric settings.  |
								 If Peer IP address is out of IP range, an error is displayed.  |
								 MCT Peer Interface  |
								 Peer Interface type matches with fabric settings and ID is reconciled.  |
