Generated Reports
The
Generated
Reports screen provides the following information about existing reports that
have been run:
| Report |
Displays the report name for each existing generated report. |
| Type |
Displays the report type for each generated report. The field at
the top of this column allows filtering the Type by keyword. |
| User |
Displays the user that generated each report. The field at the top
of this column allows filtering the User by keyword. |
| Generated At |
Displays the ending date and time that each report was
completed. |
| Action |
Select the PDF icon to download a PDF
copy of the generated report. Select the icon to
delete a generated report. |
