A join replication operation failed. The join may be lost if System Manager fails over.
Investigate the cause of the replication failure. If this does not solve the problem, contact support.
Error
A join replication operation failed. Replication action = %p1% Replication return code = %p2% Master entity type = %p3% Master entity index = %p4% Slave entity type = %p5% Slave entity index = %p6%
| Name | Type |
| p1 | uInt8 |
| p2 | uInt8 |
| p3 | xInt32 |
| p4 | HexByteArray |
| p5 | xInt32 |
| p6 | HexByteArray |
Print
this page
Email this topic
Feedback
