MM failed to send a conduit message to IOB. This may affect the PBB configuration because the IOB is not in sync with MM.
Check if all the IOBs in the slot are operational. Undo and redo the configuration to push the configuration to the operational IOBs.
Debug-Summary
Fail to send conduit message to %mesgType% to %slot% in %info%
| Name | Type |
| mesgType | String |
| slot | Slot |
| info | String |
Print
this page
Email this topic
Feedback
