Failed to look up interface configuration using ioctl(SIOCGIFCONF).
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to get interface configuration. SIOCGIFCONF = %p1% Sockets error code = %p2% IF index = %p3% Socket ID = %p4% Socket type = %p5% Socket family = %p6% Socket protocol = %p7% Application handle = %p8% Stub socket handle = %p9%
| Name | Type |
| p1 | xInt32 |
| p2 | sInt |
| p3 | xInt32 |
| p4 | sInt |
| p5 | xInt32 |
| p6 | xInt32 |
| p7 | xInt32 |
| p8 | uInt32 |
| p9 | uInt32 |
Print
this page
Email this topic
Feedback
