This message is generated when an attempt to clear the fault indicators for a maintenance association fails because a matching entry cannot be found in the databsae.
Verify the correct parameters are specified on the command line. Note the MAID must match on the type originally used. You can also verify the HAL OAM database with the command: debug hal show platform hwa-oam all
Error
Failure attempting to clear maintenance association faults in Hardware Accelerated CFM: L=%level% V=%vlanid%
| Name | Type |
| level | uInt |
| vlanid | uInt |
Print
this page
Email this topic
Feedback
