The build of the Sockets Stub being run is incorrect for this version of the Windows Operating System.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
The build of the Sockets Stub being run is incorrect for this version of the Windows Operating System. Win 2000 Build ? = %p1% Win 2000 OS (or above) ? = %p2% OS Platform Id = %p3% OS Major Version number = %p4% OS Minor Version number = %p5%
| Name | Type |
| p1 | sInt |
| p2 | sInt |
| p3 | uInt32 |
| p4 | uInt32 |
| p5 | uInt32 |
Print
this page
Email this topic
Feedback
