RingV2 with ERPSNEW!
Although RingV2 cannot be used concurrently with Ethernet Ring Protection Switching
(ERPS), you might need to configure ERPS if your ISW ring will interact
with rings on other platforms. ExtremeXOS (EXOS) switches
can run with ERPS, for example, and so can some switches from other
manufacturers.
When configuring a RingV2
ISW switch to interact with an
EXOS switch
running ERPS, keep the following principles in mind:
- The key to connecting RingV2
rings with ERPS rings is ensuring that configuration parameters align in
both systems.
- ISW default
values for some timings (associated with recovery of the ring) do not match
EXOS defaults.
- Some ISW variables
have a different accepted variable length than the equivalent variables in
EXOS.
- Carefully test your
configuration, using logs and other troubleshooting tools to understand ways
in which the settings interact with each other.
For details about configuring ERPS on an
ISW switch, see:
- "ERPS" in ISW Series Managed
Industrial Ethernet Switch Web Configuration Guide
- "Configuring ERPS from the
CLI" in ISW Series
Managed Industrial Ethernet Switch Command Reference Guide
