Coupling and Dual Homing Topologies
Coupling topology shows a coupling topology, in which adjacent rings share two switches in common. A primary port is on one switch, and a backup port is on another switch.
Coupling topology
Coupling topology: Two adjacent rings are connected at two points: a primary port and a backup port on different switches
Dual homing topology shows a dual homing topology, in which adjacent rings share a single switch in common. Both primary port and backup port are on the shared switch.
Dual homing topology: Two adjacent rings are connected at two points: a primary port and a backup port on the same switch
Ring - Each switch can be master or slave.
Coupling and dual homing - Each switch can be primary, backup, or both.
