Configuring 802.1Q Tagging from the Web UI
Go to Configuration VLANs > Port VLAN configuration table and specify the VLAN membership:
  1. Transmit unicast packets with VLAN tag 100 from Port 1 to Port 2 and Port 7.
    The ISW should tag it with VID 100. The packet only has access to Port2. For Port 2, the outgoing packet leaves as a tagged packet with VID 100.
  2. Transmit unicast packets with VLAN tag 200 from Port 1 to Port 2 and Port 7.
    The ISW should tag it with VID 200. The packet only has access to Port7. The outgoing packet on Port 7 is stripped of its tag as an untagged packet.
  3. Transmit unicast packets with VLAN tag 100 from Port 2 to Port 1 and Port 7.
    The ISW should tag it with VID 100. The packet only has access to Port1. For Port 1, the outgoing packet leaves as a tagged packet with VID 100.
  4. Transmit unicast packets with VLAN tag 200 from Port 7 to Port 1 and Port 2.
    The ISW should tag it with VID 200. The packet only has access to Port1. The outgoing packet on Port 1 will leave as a tagged packet with VID 200.
  5. Repeat the above steps using broadcast and multicast packets.
