If you want to reset the configuration to default, but keep management IP settings, do the following:
Execute the command: reload defaults
keep-ip
Check interface
VLAN and IP address, and confirm only management IP
setting is kept.
Execute the command: copy running-config
startup-config
If you want to reset all configurations to the default:
Check interface VLAN and IP address, and confirm they all change to default settings.
startup-config
