The ISW series switches support PoE function for connected powered device. The operation mode contains 802.3af (15.4W), 802.3at (30W). Each port has five classes for selection (class 0–4). Total power budget of the system is up to 240 watts.
For power management friendly use, it supports power scheduler for each PoE port. Each time interval is 30 minutes from Sunday to Saturday. Customer can select which interval to set PoE on or PoE off. It also supports PoE reset function to power off, then power on the PoE function on a port at certain time. Maximum five time can be created in a week.
