ISW Series Managed Industrial Ethernet Switch Hardware Installation & User Guide
Installing Industrial Switches
> Connecting & Logging in to the Switch
Published April 2022
Preface
ISW-Series Switch Overview
8-port Switch Models
12-port Switch Models
28-port Switch Model
Power Supplies for Use with Your Switch
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Requirements for PoE Devices
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Mount the Switch
Connect Power Supplies, Alarm Relay, and Ground Connection
Turn on the Switch
Connect to the Management Console
Configure the Switch for Use
Monitor the Switch
System Status LEDs
Copper RJ45 Port LEDs
SFP and SFP+ Port LEDs
PoE LEDs
Reset, Upgrade or Downgrade Software
System Reset
Reset Configuration Defaults via CLI Command
Reset Configuration Defaults via Web UI
Upgrade and Downgrade Software
Important Deployment Considerations
ISW Series Technical Specifications
Power Options
Weights and Physical Measurements
Performance & Scale
CPU, Memory
Console Connector Pinouts
Standards
Environmental Specifications
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Federal Communications Commission (FCC) Notice
Connect to
ISW
Ethernet port (RJ45 Ethernet port) using factory default IP:
192.0.2.1
Log in with default account and password (
admin / [none]
Optional:
Change the IP with commands listed below:
enable configure terminal interface vlan 1 ip address xxx.xxx.xxx.xxx xxx.xxx.xxx.xxx exit
To log in to the web interface, enter your switch's IP address in a web browser.
Refer to
Web Browser Support
to ensure your browser is supported.
Enter the account name and password.
Click
Sign in
For information on configuring and monitoring the switch through the web interface, see the
ISW-Series Managed Industrial Ethernet Switch
Web Configuration Guide
