Connecting the Power Terminal Block
The DC power interface is a 6-pin terminal block with polarity signs on the top panel. The ISW can be powered from two power supply (input range 12V – 58V). The DC power connector is a 6-pin terminal block; there is alarm contact on the middle terminal block.
The switch can be powered from two power supplies (input range 12V – 58V). Insert the positive and negative wires into V+ and V- contacts on the terminal block respectively and tighten the wire-clamp screws to prevent the wires from being loosened.
The DC power should be connected to a well-fused power supply.
Power Supplies
Power Connector (6P Terminal Block)
Input DC 12-58V
PWR1 +/- Power Input 1 +/-
PWR2 +/- Power Input 2 +/-
ALM Alarm relay output
