You can configure a device to use the
		default IPv4 route as a valid next hop for a BGP4 route. This configuration is helpful in
		certain cases, such as when a device is acting as an edge device.
By default, a device does not use a default route to resolve a BGP4 next-hop route. If the IPv4 route lookup for the BGP4 next-hop does not result in a valid IGP route (including static or direct routes), the BGP4 next-hop is considered to be unreachable and the BGP4 route is not used. You can configure the device to use the default route as a valid next hop.
				Access global configuration
					mode.
					device# configure terminal
				Access BGP configuration mode.
					device(config)# router bgp
				Access address-family IPv4
					unicast configuration mode.
					device(config-bgp-router)# address-family ipv4 unicast
				Configure the device to use the
					device(config-bgp-ipv4u)# next-hop-enable-default
