You can configure a Domain Name System (DNS) domain and DNS gateway addresses to resolve host names to IP addresses.
device# configure terminal
device(config)# ip dns domain-name mycompany.com
device(config)# ip dns name-server 10.157.22.199
                The first DNS server IP address added to the domain name configuration will be considered the Primary DNS server. You can add up to five (5) additional DNS servers for the domain name. Any combination of IPv4 or IPv6 DNS name servers can be configured. For example, you could choose to add 2 IPv6 name servers alongside 4 IPv4 name servers. However, you cannot add more than six name servers for the domain.
If you add more than six name servers for the domain, the following error message displays.
too many 'ip dns name-server', 7 configured, at most 6 must be configured
device(config)# exit
                device# traceroute mycompany.com
Sending DNS Query to 10.157.22.199
Tracing Route to IP node 10.157.22.80
To ABORT Trace Route, Please use stop-traceroute command.
Traced route to target IP node 10.157.22.80:
IP Address    Round Trip Time1    Round Trip Time2
10.95.6.30    93 msec             121 msec
                The following example configures a DNS domain and default and additional secondary DNS name server addresses for the domain www.mycompany.com.
device(config)# ip dns domain-name www.mycompany.com
device(config)# ip dns name-server 10.96.7.15
            This example configures six (6) DNS name servers for the domain www.mycompany.com. Of these six (6) domain names, two (2) are IPv6 DNS resolvers.
device(config)# ip dns name-server 10.24.15.150
device(config)# ip dns name-server 10.24.18.125
device(config)# ip dns name-server 172.26.71.80
device(config)# ip dns name-server 200:f8::ed:3000
device(config)# ip dns name-server 2001:eb::780:ff87
device(config)# ip dns name-server 10.37.89.80
