Duplicate Stanzas in a BGP Flowspec Route
		Map
  Duplicate stanzas have the same match
		statements. BGP installs only one local flowspec route for a specific key (match statement)
		and has rules for handling duplicate stanzas.
			- BGP traverses the flowspec route map in
				ascending order of sequence number when:
					- The route map is first applied with the
							distribute command
					- Modifications are made to an
						active route map.
			- While traversing each stanza, BGP attempts to prepare or modify a local flowspec
				route.
			- When the distribute command is
				used to activate a route map that contains duplicate stanzas, the stanza with the
				higher sequence number becomes active only if it has different set commands. Otherwise
				the stanza with the lower sequence number remains active. For example: Stanzas A and
				B are duplicates. Stanza A has a lower sequence number than stanza B. Therefore:
					- When A and B have same
							match
						and set
						command content, A is installed, B is not allowed to be active, and a RASlog
						message is triggered.
							match
						command content but different set command
						content, A first becomes active, then B replaces A, and a RASlog message is
						triggered.
			- When a change is made to the match content of an
				active stanza, the stanza with the lowest sequence number from the remaining
				duplicates is selected as active. For example: a route map has three duplicate
				stanzas (A, B, and C). For these stanzas, the match command content
				is the same but the set command content differs. Also, the sequence number of A is lower
				than the sequence number of B, which is lower than the sequence number of C.
				Therefore, assuming that stanza C is active:
					- When the match content
						in stanza C is modified, the stanza with the lowest sequence number among
						stanza C's former duplicates (A) is selected as active along with the new
						stanza C and a RASlog message is triggered.
					- When stanza C is removed, the
						stanza with the lowest sequence number among stanza C's former duplicates
						(A) is selected as active and a RASlog message is triggered.
