Extreme SLX-OS Software Licensing Guide, 20.6.1
Software Licensing Overview
Software license terminology
Software licensing configuration tasks
> Generating a license
Published March 2024
Preface
About This Document
What's New in This Document
Supported Hardware
Software-based licensing overview
How software-based licensing works
License types
Licensing rules
Licensing considerations
Querying a license
Software Licensing Tasks
Installing a license
Displaying a license
Adding or removing a SAU license
Displaying the device license ID
Removing licenses
Troubleshooting licensing issues
License is not properly installed
Dynamic Ports on Demand Licensing
Capacity on Demand and Dynamic Ports on Demand overview
Managing automatic POD port assignments
Mapping port assignments to a POD port set
Activating the Dynamic POD feature
Displaying the Dynamic POD assignments
Overriding Dynamic POD assignments
Reserving a port assignment
Releasing a port from a POD set
SLX-OS Licensed Features and Part Numbers
The following procedure demonstrates how to generate and obtain a software license.
Log in to the
Extreme
Portal at
https://extremeportal.force.com/ExtrLicenseLanding
If you do not have an Extreme portal account, select
Create a new Extreme Portal account.
The following figure shows the Extreme Portal login window.
Extreme portal login window
Enter your email and password. Click
Log In
The
Licenses Home
window appears.
Licenses Home window
Select
Assets
Licenses Home
option. Click
Generate License
The
Generate License
window is displayed.
Generate License window
Enter the VID. Click
Next.
The VID has 20 alphanumeric characters with hyphens.
Enter the unique identifier of the HW (or the serial number of the LID). Click
Submit
You must check the box to agree to the Terms and Conditions.
HW serial number window
The VID is displayed. The example below displays voucher information for a non-capacity license.
Voucher Details window
Click
Download
to download a copy of the license.
A license can be downloaded after license generation or when a unit is queried. The license is not emailed.
In example below, the contents of the XML license are displayed, including the license SKU and license keys.
License file window
