The Dynamic POD feature is only used on the 100 GbE ports of the SLX 9540 platform . With the Dynamic POD feature, you can use the base port set plus the number of additional ports you purchased. All ports that do not receive a POD assignment and are trying to come online will go offline. The show ip interface brief and show interface ethernet slot/port commands display the reason for the port-disabled status as related to POD licensing.
The Dynamic POD mechanism detects the ports that have active links, and makes assignments based on the remaining pool of vacancies:
If the given assignment order does not align with your intended use of the ports, you can make adjustments using the dpod slot/port reserve or the dpod slot/port release configuration commands. Refer to Overriding Dynamic POD assignments for more information.
