You can add a SAU license using the license eula accept command. The EULA text can be displayed using the show license eula command.
The following example displays the EULA text.
device# show license eula
Use of the features enabled via the "license eula accept" CLI requires a license to
be purchased within 30 days. By accepting the EULA you indicate that you
have read and accept the Extreme End User License Agreement found at the following URL.
[https://learn.extremenetworks.com/rs/641-VMV-602/images/Extreme-Networks-End-User-License-Agreement.pdf].
	 When the license eula accept command is entered, you are agreeing to purchase a license within a specific timeframe. You can begin using the features immediately.
device# license eula accept ADVANCED_FEATURES
2016/11/24-23:58:11, [SEC-1120], 41,, INFO, SLX9540, License EULA entry added for ADVANCED_FEATURES feature (capacity 0).
EULA accepted for feature [ADVANCED_FEATURES]
Use of the ADVANCED_FEATURES feature requires a license to be purchased within 30 days.
By accepting the EULA you indicate that you have read and accept the Extreme End USER License Agreement found at the following URL
You can decline the EULA acceptance now by entering "license eula decline ADVANCED_FEATURES"
at the CLI prompt; declining the EULA will prevent use of the licensed feature.
Chassis:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
		Advanced Features license
		Feature name:ADVANCED_FEATURES
		License is Trust Based
		EULA acceptance date: Thu Nov 24 23:58:11 2016
	 If the SAU license is not accepted using the license eula accept command, the Advanced features cannot be used. In the following example for the Guest OS for TPVM feature, the license eula accept command was not accepted prior to the configuration. You must accept the SAU license before you can begin using the Advanced features.
deviceSLX# tpvm install ERROR: ADVANCED_FEATURES license is missing. Please install ADVANCED_FEATURES license for TPVM operation. device#
You can remove a SAU license using the license eula decline command. The following example displays removing a SAU license (Advanced features).
device# license eula decline ADVANCED_FEATURES
 EULA removed for feature [ADVANCED_FEATURES]
	 When the license eula decline command is entered, you are no longer able to use the licensed features. Before you can "decline" the licensed features, all configuration settings related to the feature must be restored to default settings.
The following CLI message is displayed when you attempt to configure a feature that requires a SAU license, and you have not accepted the EULA and there is no SAU license installed for that feature.
device(config)# router mpls
%Error: Advanced Features License not found.
