Configuring the underflow limit
The user can configure the underflow limit at the LSP level as well as in the auto-bandwidth template. The inheritance rules applied are the same as other auto-bandwidth parameters. The default value of underflow-limit is zero (0).
To configure the underflow-limit in an auto-bandwidth template, complete the following steps.
  1. Enable the device for configuration.
    device>configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable the auto-bandwidth template and select template. In this example, template1 is selected.
    device(config-router-mpls)# autobw-template template1
  4. Configure the underflow limit. In this example, the underflow limit is configured to 10.
    device(config-router-mpls-autobw-template-template1)# underflow-limit 10
The following example combines the steps above to set the underflow-limit in an auto-bandwidth template.
device>configure
Configuring the underflow-limit for an individual LSP.
To configure the underflow-limit for an individual LSP, complete the following steps.
    device>configure
  3. Enable LSP configuration ans select target LSP. In this example, LSP1 is selected.
    device(config-router-mpls)# lsp lsp1
  4. Enable auto-bandwidth.
    device(config-mpls-lsp-lsp1)# autobw
  5. Enable and configure the underflow-limit. In this example, the underflow-limit is configured to 10.
    device(config-router-mpls-lsp-lsp1-autobw)# underflow-limit 10
In the following example, the steps above are combined to configure the underflow-limit for individual LSP1 to 10 .
device>configure
Clearing the underflow-limit configuration
To clear the underflow-limit configuration, use the same command as above with the no option. The underflow-limit is set back to the default value of zero (0).
    device>configure
    device(config-router-mpls-lsp-lsp1-autobw)# no underflow-limit 10
In the following example, the steps above are combined to clear the underflow-limit configuration and set the configuration back to the default value of zero (0 ).
device>configure
