Configures, retrieves, and modifies IP address prefix list.
| URI | Description |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance} | Configures IP address prefix list. |
| GET URIs | Description |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance} | Retrieves IP address prefix list. |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance}/ge | Retrieves minimum IP prefix length. |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance}/le | Retrieves maximum IP prefix length. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><action-ipp>{action-t}</action-ipp><prefix-ipp>{inet:ipv4-prefix}</prefix-ipp></prefix-list> | Configures IP address prefix list. |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><ge>{prefix-len-t}</ge></prefix-list> | Configures minimum IP prefix length. |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance} | <prefix-list><le>{prefix-len-t}</le></prefix-list> | Configures maximum IP prefix length. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance}/ge | <ge>{prefix-len-t}</ge> | Configures minimum IP prefix length. |
| <base_URI>/config/running/ip/prefix-list/{name},{seq-keyword},{instance}/le | <le>{prefix-len-t}</le> | Configures maximum IP prefix length. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ip/prefix-list/PRLIST1,seq,5
None
<prefix-list xmlns="urn:brocade.com:mgmt:brocade-ip-policy" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ip/prefix-list/PRLIST1%2Cseq%2C5"> <name>PRLIST1</name> <seq-keyword>seq</seq-keyword> <instance>5</instance> <action-ipp>permit</action-ipp> <prefix-ipp>17.0.0.0/16</prefix-ipp> <ge>18</ge> <le>24</le> </prefix-list>
The following example uses the PUT option to configure IP address prefix list.
http://host:80/rest/config/running/config/running/ip/prefix-list/PRLIST1,seq,5/ge
None
The following example uses the DELETE option to remove IP address prefix list.
None
None
