interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway
Configures DHCP relay gateway.
Resource URIs
URI Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway Configures DHCP relay gateway. Valid interface types: Ethernet, Ve.
GET URIs Description
POST URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay <gateway>{ip-address}</gateway> Configures DHCP relay gateway. Valid interface types: Ethernet, Ve.
PATCH URIs Payload Description
<base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/dhcp/relay/gateway <gateway>{ip-address}</gateway> Configures DHCP relay gateway. Valid interface types: Ethernet, Ve.
PUT URIs Payload Description
DELETE URIs
Parameters
address
IP address of the gateway.
Usage Guidelines
GET, POST, PATCH, PUT, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ve/11/ip/dhcp/relay/gateway
None
<gateway xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/Ve/11/ip/dhcp/relay/gateway">11.1.2.1</gateway>
URI
The following example uses the POST option to configure DHCP relay gateway.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay
<gateway>10.10.10.10</gateway>
None
URI
The following example uses the DELETE option to remove DHCP relay gateway.
http://host:80/rest/config/running/interface/ethernet/%221/10%22/ip/dhcp/relay/gateway
None
None
