ip/dhcp/relay
Configures, modifies, or retrieves IP Dynamic Host Configuration Protocol (DHCP).
Resource URIs
URI Description
<base_URI>/config/running/ip/dhcp/relay Configures DHCP relay.
GET URIs Description
<base_URI>/config/running/ip Configure Internet Protocol (IP).
<base_URI>/config/running/ip/dhcp Configures Dynamic Host Configuration Protocol (DHCP).
<base_URI>/config/running/ip/dhcp/relay/information/option Configures DHCP relay.
POST URIs Payload Description
<base_URI>/config/running/ip/dhcp/relay/information <option> </option> Configures DHCP relay option.
PATCH URIs Payload Description
PUT URIs Payload Description
DELETE URIs
Parameters
option
Enables DHCP relay information.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ip
None
<dhcp xmlns="urn:brocade.com:mgmt:brocade-dhcp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ip/dhcp">
  <relay y:self="/rest/config/running/ip/dhcp/relay">
    <information y:self="/rest/config/running/ip/dhcp/relay/information">
      <option>true</option>
    </information>
  </relay>
</dhcp>
URI
The following example uses the POST option to configure IP DHCP relay option.
http://host:80/rest/config/running/ip/dhcp/relay/information
None
URI
The following example uses the DELETE option to remove IP DHCP relay option.
None
None
