mct-state
Displays MCT operational information.
Resource URIs
URI Description
<base_URI>/operational-state/mct-state Displays MCT operational information.
<base_URI>/operational-state/mct-state/show-cluster/{cluster-id} Displays the complete client-information list, which includes cluster-id, client-id, client-name, client-esi, client-interface, client-state, active vlan list, configured vlan list
<base_URI>/operational-state/mct-state/show-cluster/{cluster-id}/cluster-name Displays the cluster name configured.
<base_URI>/operational-state/show-cluster/{cluster-id}/cluster-status Provides the cluster status: True for Up status, False for Down status.
<base_URI>/operational-state/show-cluster/{cluster-id}/client-isolation-status Provides the configured client-isolation status(strict mode or Loose mode).
<base_URI>/operational-state/mct-state/show-cluster/1/num-peers Displays number of peers.
<base_URI>/operational-state/mct-state/show-cluster/1/num-clients Displays number of clients.
<base_URI>/operational-state/mct-state/show-cluster/1/num-config-vlans Displays number of configured VLANs.
<base_URI>/operational-state/mct-state/show-cluster/1/num-active-vlans Displays number of active VLANs.
<base_URI>/operational-state/show-cluster/{cluster-id}/ client-info-list/{cluster-id},{client-id}/client-name Displays the client-name information.
<base_URI>/operational-state/show-cluster/{cluster-id}/ client-info-list/{cluster-id},{client-id}/client-interface Displays the configured client-interface information.
<base_URI>/operational-state/mct-state/show-cluster/1/client-info-list/1/1/client-state Displays client state.
<base_URI>/operational-state/mct-state/show-cluster/1/client-info-list/1/1/num-config-vlans Displays number of VLANs.
Usage Guidelines
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/operational-state/mct-state
None
<mct-state xmlns="urn:brocade.com:mgmt:brocade-nsm-operational" y:self="/rest/operational-state/mct-state">
</mct-state>
