ntp
Configures, modifies, or retrieves NTP commands.
Resource URIs
URI Description
<base_URI>/config/running/ntp NTP commands.
GET URIs Description
<base_URI>/config/running/ntp Displays NTP configuration.
<base_URI>/config/running/ntp/authentication-key Displays Authentication key.
<base_URI>/config/running/ntp/server Displays NTP server information.
POST URIs Payload Description
<base_URI>/config/running/ntp <server><ip>(ip-address)</ip><use-vrf>(vrf-name)</use-vrf></server> Configures NTP server.
<base_URI>/config/running/ntp <authentication-key><keyid>(unit32)</keyid><md5>{string}</md5></authentication-key> Configures authentication key and MD5 message-digest algorithm.
<base_URI>/config/running/ntp <server><ip>(ip-address)</ip><use-vrf>(vrf-name)</use-vrf><key>(unit32)</key></server> Configures NTP server key.
<base_URI>/config//running/ntp/disable <all> | <server> Disables the NTP server/client mode. Disabling the NTP server/client mode does not remove the configuration.
<base_URI>/config/running/ntp/authentication-key <key-id-1 > <key-id-2> <key-id-n>
This command enables or disables the NTP authentication at global level. If the authentication is enabled, the NTP packets
from servers, peers, clients not having MAC is dropped. Only those servers/peers configured with key authentication is
considered for time synchronization. Client requests only with authentication is served, whose key-IDs match with one of the
trusted key-IDs.
<base_URI>/config/running/ntp/master < key key-id > < use-vrf vrf-name >
Configures the device as an authoritative NTP Server. ntp master enables device to use its own clock to synchronize with
peers/clients. This command is not effective, if the NTP is enabled in client-only mode.
<base_URI>/config/running/ntp/server <ipv4 | ipv6 > <vrf name > Specifies or adds an NTP server IP address and optionally associates an authentication key to the server.
<base_URI>/config/running/ntp/trusted-key <key-id-1 > <key-id-2> <key-id-n>
Configures additional subset of trusted key-IDs which can be used for NTP and client authentication. The keys
configured for server/peer is implicitly considered as part of trusted keys.
<base_URI>/config/running/ntp/peer/ <ipv4 | ipv6 > <vrf name > Configures the NTP peers and specify the peers to synchronize the system clock. Maximum 8 NTP peers can be configured
DELETE URIs
<base_URI>/config/running/ntp/server/{ip}/use-vrf
<base_URI>/config/running/ntp/server/{ip}/user-vrf/{vrf-name},{keyid}
Parameters
authentication-key
Configures authentication key parameters.
server
Configures NTP server parameters.
ip
Configures the source ip to be used for NTP.
keyid
Specifies authentication key ID. Valid range is from 0 to 65535.
use-vrf
Specifies the VRF to be used.
key
Specifies the key.
md5
Specifies a string for the MD5 message-digest algorithm. The string can be a maximum of 15 ASCII characters.
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ntp
None
<ntp xmlns="urn:brocade.com:mgmt:brocade-ntp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/ntp">
  <server y:self="/rest/config/running/ntp/server/10.1.1.2%2Cmgmt-vrf">
    <ip>10.1.1.2</ip>
    <use-vrf>mgmt-vrf</use-vrf>
  </server>
</ntp>
URI
The following example uses the POST option to configure authentication-key.
  <keyid>50</keyid>
  <md5>{teesting}</md5>
URI
The following example uses the DELETE option to remove NTP configuration.
None
