ipv6/nd
Configures, modifies, or retrieves Neighbor Discovery commands at global level.
Resource URIs
URI Description
<base_URI>/config/running/ipv6/nd Configures Neighbor Discovery commands.
GET URIs Description
<base_URI>/config/running/ipv6/nd/global-suppress-ra Sets globally suppress-ra.
<base_URI>/config/running/ipv6/nd/ra-dns-server/{string} Sets global DNS server option applied on all ND6 interfaces
<base_URI>/config/running/ipv6/nd/ra-domain-name/{string}/lifetime-multplier Set global domain name option that applied on all ND6 interfaces and applies Lifetime multiplier for DNS Search List option.
POST URIs Payload Description
<base_URI>/config/running/ipv6/nd <global-suppress-ra>(enumeration)</global-suppress-ra> Sets globally suppress-ra.
<base_URI>/config/running/ipv6/nd <ra-dns-server><dns-server-prefix-global>{dns-server-prefix}</dns-server-prefix-global><lifetime-multplier>(decimal)</lifetime-multplier></ra-dns-server> Set global DNS server option applied on all ND6 interfaces.
<base_URI>/config/running/ipv6/nd <ra-domain-name><domain-name-string-global>{name}</domain-name-string-global><lifetime-multplier>{decimal}</lifetime-multplier></ra-domain-name> Set global domain name option that applied on all ND6 interfaces.
PUT URIs Payload Description
<base_URI>/config/running/ipv6/nd/ra-dns-server/{ipv6_address_of_name_server}/lifetime-multplier <lifetime-multplier>(decimal)</lifetime-multplier> Lifetime multiplier for the DNS Server option
<base_URI>/config/running/ipv6/nd/ra-domain-name/{name}/lifetime-multplier <lifetime-multplier>(decimal)</lifetime-multplier> Lifetime multiplier for DNS search list option.
DELETE URIs
Usage Guidelines
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
URI
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/ipv6/nd/global-suppress-ra
None
<nd xmlns="urn:brocade.com:mgmt:brocade-ipv6-nd-ra" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/ipv6/nd">
  <global-suppress-ra>true</global-suppress-ra>
  <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/2100:21:2134::566">
    <dns-server-prefix-global>2100:21:2134::566</dns-server-prefix-global>
  </ra-dns-server>
  <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/3600:36::1">
    <dns-server-prefix-global>3600:36::1</dns-server-prefix-global>
  </ra-dns-server>
  <ra-dns-server y:self="/rest/config/running/ipv6/nd/ra-dns-server/3600:36::11">
    <dns-server-prefix-global>3600:36::11</dns-server-prefix-global>
  </ra-dns-server>
  <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.in">
    <domain-name-string-global>test.in</domain-name-string-global>
  </ra-domain-name>
  <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.sk">
    <domain-name-string-global>test.sk</domain-name-string-global>
  </ra-domain-name>
  <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.uk">
    <domain-name-string-global>test.uk</domain-name-string-global>
  </ra-domain-name>
  <ra-domain-name y:self="/rest/config/running/ipv6/nd/ra-domain-name/test.us">
    <domain-name-string-global>test.us</domain-name-string-global>
  </ra-domain-name>
</nd>
URI
The following is an example of the POST operation to set global DNS server option applied on all ND6 interfaces.
<ra-dns-server><dns-server-prefix-global>3300:36::11</dns-server-prefix-global><lifetime-multplier>199</lifetime-multplier>
</ra-dns-server>
None
URI
The following is an example of the DELETE operation to remove ilfetime multiplier for the DNS Server option.
http://host:80/rest/config/running/ipv6/nd/ra-dns-server/3400:36::11/lifetime-multplier
None
None
