bna-config-cmd
Copies configuration data to or from the system.
Resource URIs
URI Description
<base_URI>/operations/bna-config-cmd Copy configuration data to or from the system.
Parameters
session-id
This ID is used along with bna-config-cmd-status API to get the status of this operation (inprogress/complete).
status
Displays the status of this operation (inprogress/complete).
Usage Guidelines
Only POST operation is supported.
URI
http://host:80/rest/operations/bna-config-cmd
<bna-config-cmd>
  <src>running-config</src>
  <dest>startup-config</dest>
</bna-config-cmd>
<output xmlns='urn:brocade.com:mgmt:brocade-ras'>
  <session-id>0</session-id>
  <status>in-progress</status>
</output>
