            Connect the cables after you have installed the transceiver.
                Remove the protective covers
                    from the transceiver and from the connectors on each end of the cable.
                Insert the cable connector into the transceiver connector until it clicks into
                    place.
                Plug the other end of the cable into the appropriate port on the other
                    device.
Some fiber-optic cables can be
                    terminated at the other end with two separate connectors, one for each
                    fiber-optic strand. In this case, ensure that the transmit fiber-optic strand
                    from the appliance is connected to the receive port of the other device, and the
                    receive fiber-optic strand on the appliance is connected to the transmit port of
                    the other device.
                If a transceiver port is unused, cover the port using a dust cover.
Warning
Fiber-optic transceivers use Class 1 lasers. Do not use
                        optical instruments to view the laser output. The use of optical instruments
                        to view laser output increases eye hazard. When viewing the output optical
                        port, power must be removed from the network adapter.
