Data ports 3 and 4 provide SFP28 ports that can support 1, 10, and 25Gbps transceivers. Refer to the transceivers and cables datasheet for a list of pluggable transceivers supported for 2130C.
To install a transceiver:
If there is a protective dust cover on the transceiver connector, do not remove it at this time.
