Connect the Data Ports
The 2130C data ports 1 and 2 are 1/10 GbE RJ45 ports. Ensure that the device to be connected at the other end of the segment is powered on.
To connect a twisted pair cabling:
  1. Connect the twisted pair segment to the appliance by inserting the RJ45 connector on the twisted pair segment into the desired RJ45 port.
  2. Verify that a link exists by checking that the Activity Link LED is on (solid green or blinking green). If the Activity Link LED is off, perform the following steps until it is on:
    1. Verify that the cabling being used is Category 5 or better (Category 6 or better for 10Gbps connection). The cable should have an impedance between 85 and 111 ohms and a maximum length of 328 feet (100 meters).
    2. Verify that the device at the other end of the twisted pair segment is turned on and is properly connected to the segment.
    3. Verify that the RJ45 connectors on the twisted pair segment have the proper pinouts, and check the cable for continuity.
  3. If a link is not established, contact Extreme Networks.
