Connect to a Power Source
The power source is located in the back panel of the appliance and the power button is located in the front control panel. To connect the appliance to a power source:
  1. Connect the two AC power cables to power supplies 1 and 2.
    These two power supplies combine to create an optional redundant power supply.
  2. Plug the other end of the cables into grounded electrical outlets or to separate power sources such as an uninterrupted power supply (UPS) or a power distribution unit (PDU).
  3. Power On the appliance.
    The power button is on the front control panel.
