Ethernet Ports LED Information
The Inter-Cluster-Connect ports and data ports 1 and 2 include two LEDs located on either side of the port. For data ports 3 and 4 both LEDs are on the left side of the port. Use the information in the following tables to interpret the LED patterns.
Table 1. RJ45 Port LEDs (Inter-Cluster-Connect 1 and 2)
LED typeLED patternStatus
Network speed (left)Off100 Mbps
Solid amber1,000 Mbps (1 Gbps)
Solid green10,000 Mbps (10 Gbps)
Link activity (right)OffNo link
Solid greenActive link
Blinking greenData traffic activity
Table 2. RJ45 Port LEDs (Data Ports 1 and 2)
Network speed (right)Solid amber1,000 Mbps (1 Gbps)
Link activity (left)OffNo link
Table 3. SFP28 Port LEDs (Data Ports 3 and 4)
Network speed (right)Solid amberLess than 25,000 Mbps (25 Gbps)
Solid green25,000 Mbps (25 Gbps)
