5120 Series Installation Guide
> Remove and Replace Components
Extreme Networks, Inc. July 01, 2025
Introduction to the 5120 Series Installation Guide
New in this Guide
5120-44X-4Y-2C Switch Features
5120-24X-4Y Switch Features
5120-24XT-4Y Switch Features
Port Partitioning
Manage Your Switch
Universal Ethernet Ports
Fans Modules for Use with Your Switch
Fan Modules
Power Supplies for Use with Your Switch
550 W AC Power Supplies
Build Stacks
Introduction to Stacking
Build Basic Stacks
Slot Numbers in Stacks
SummitStack Topologies
SummitStack Terms
Plan to Create Your Stack
Enable and Disable the Stacking Support Option
Recommendations for Placing Switches for Stacked Operation
Recommendations for Configuring Stacks
Combine Switches from Different Series
Select Stacking Cables
Use the Extreme Stacking Tool
Set up the Physical Stack
Connect the Switches to Form the Stack Ring
Examples of Valid Stacking Configurations
Example: Basic Stack with Four Switches
Example: Basic Stack with Eight Switches
Example: Stacked Switches across Several Racks
Connect Your Stack to the Management Network
Site Preparation
Plan Your Site
Set Up the Wiring Closet
Control the Temperature
Control the Humidity Level
Ground the Rack
Secure the Rack
Install Cable
Handle Fiber Optic Cable
Cable Distances and Types
Use RJ45 Connector Jackets
Meet Power Requirements
Power Supply Requirements
Power Cord Requirements
Select a UPS
Install Your Switch
Install Internal Power Supplies
Install Optional Components
Turn on the Switch
Log In for the First Time on Switch Engine
Remove a Device from a Two-Post Rack
Replace Internal Power Supplies
Airflow Direction Requirements
Replace an Internal 550W AC Power Supply
Replace Fan Modules
Replace a Fan Module
Monitor the Switch
System Status LEDs
550 W AC Power Supply LEDs
Technical Specifications
5120 Series Technical Specifications
Fan and Acoustic Noise
CPU, Memory
Mean Time Between Failures
Power Specifications
Environmental
Standards
EMI/EMC Standards
Console Connector Pinouts
General Safety Precautions
Maintenance Safety
GBIC, SFP (Mini-GBIC), QSFP+, XENPAK, and XFP Regulatory Compliance
Cable Routing for LAN Systems
Select Power Supply Cords
Battery Notice
Battery Warning - Taiwan
EMC Warnings
Japan (VCCI Class A)
Korea EMC Statement
Use the information in the following topics to remove or replace components.
Section contents:
Replace Fan Modules
