Use the following instructions to turn on the switch
An AC power cord is not included with the AC power supply. You can purchase AC power cords for use in the US and Canada from Extreme Networks or from your local supplier. The cord must meet the requirements listed in Power Cord Requirements for AC-Powered Switches and AC Power Supplies.
The switch does not have a power button, so connecting the power cable at both ends turns the switch on. The grounding connection in the power receptacle and in the power cord properly ground the power supply and extend that grounding to the switch.If the PSU LEDs do not turn green, refer to 550 W AC Power Supply LEDs for troubleshooting information.
When the PSU LED has turned green, follow the instructions in Activate and Verify the Switch.
