Power Specifications
The following tables contain power supply specifications, power consumption, and heat dissipation information for 5120 Series switches.
Power Supply Specifications
| XN-ACPWR-550W-FB-A | XN-ACPWR-550W-BF-A |
| Voltage Input Range (Nominal) | 100VAC-127VAC / 200VAC-240VAC | 100VAC-127VAC / 200VAC-240VAC |
| Line Frequency Range | 47Hz to 63Hz | 47Hz to 63Hz |
| Power Supply Input Socket | IEC/EN 60320 C14 | IEC/EN 60320 C14 |
| Power Cord Input Plug | IEC/EN 60320 C13 | IEC/EN 60320 C13 |
Minimum/Maximum Power Consumption and Heat Dissipation
| Switch Model | Minimum Power Consumption (W) | Minimum Heat Dissipation (BTU/hr) | Maximum Power Consumption (W) | Maximum Heat Dissipation (BTU/hr) |
| 5120-24X-4Y | 29.95 | 102.10 | 172.82 | 589.69 |
| 5120-24XT-4Y | 36.78 | 125.49 | 173.09 | 590.62 |
| 5120-44X-4Y-2C | 61.6 | 210.18 | 315.52 | 1076.60 |
