| 715W AC PSU | 1100W AC PSU | 2000W AC PSU1 | |
| Voltage Input Range (Nominal) | 100-127/200-240 VAC | 100-127/200-240 VAC | 100-127/200-240 VAC |
| Line Frequency Range | 50Hz to 60Hz | 50Hz to 60Hz | 50Hz to 60Hz |
| Power Supply Input Socket | IEC/EN60320 C16 | IEC/EN60320 C16 | IEC/EN60320 C16 |
| Power Cord Input Plug | IEC/EN60320 C15 | IEC/EN60320 C15 | IEC/EN60320 C15 |
| Operating Temperature |
0°C to 55°C (32°F to 131°F) Normal Operation |
0°C to 50°C (32°F to 122°F) Normal Operation | 0°C to 50°C (32°F to 122°F) |
1 200-240 VAC is required to achieve full 2000W output. If run at 100-120VAC, output is limited to 1100W.
| Switch Model | Minimum Power Consumption (W) | Minimum Heat Dissipation (BTU/hr) | Maximum Power Consumption (W)1 | Maximum Heat Dissipation (BTU/hr)2 |
| 5720-24MW | 86 | 293 | 2549 | 389 |
| 5720-24MXW | 105 | 359 | 2576 | 416 |
| 5720-48MW | 103 | 354 | 4078 | 543 |
| 5720-48MXW | 105 | 359 | 4096 | 561 |
1 Includes maximum PoE load (W) through the switch
2 Does not include PoE load heat dissipated through external electronic load
| Switch Model | 1 x 715W | 2 x 715W | 1 x 1100W | 2 x 1100W | 1 x 2000W @ 110-132V AC | 2 x 2000W @ 110-132V AC | 1 x 2000W @ 220-264V AC | 2 x 2000W @ 220-264V AC |
| 5720-24MW | 450W | 1093W | 835W | 1825W | 835W | 1825W | 1735W | 2160W |
| 5720-24MXW | 450W | 1093W | 835W | 1825W | 835W | 1825W | 1735W | 2160W |
| 5720-48MW | 450W | 1093W | 835W | 1825W | 835W | 1825W | 1735W | 3535W |
| 5720-48MXW | 450W | 1093W | 835W | 1825W | 835W | 1825W | 1735W | 3535W |
It is recommended that primary and secondary power supply units (PSUs) be of the same type to support optimal PoE operation.
